resources:pcb [2019/10/17 15:02]
resources:pcb [2020/01/02 12:08]
Line 9: Line 9:
 There was a skillshare introducing the better methods in February 2018. Due to the size, the presentation slides are split into three files: {{:skillshare:solderlessBreadboards01-03.pdf|avoiding solderless breadboards 1 of 3}}, {{:skillshare:solderlessBreadboards02-03.pdf|avoiding solderless breadboards 2 of 3}}, {{:skillshare:solderlessBreadboards03-03.pdf|avoiding solderless breadboards 3 of 3}}. Those files have the slides in the first half, and the slides plus notes in the second half. There was a skillshare introducing the better methods in February 2018. Due to the size, the presentation slides are split into three files: {{:skillshare:solderlessBreadboards01-03.pdf|avoiding solderless breadboards 1 of 3}}, {{:skillshare:solderlessBreadboards02-03.pdf|avoiding solderless breadboards 2 of 3}}, {{:skillshare:solderlessBreadboards03-03.pdf|avoiding solderless breadboards 3 of 3}}. Those files have the slides in the first half, and the slides plus notes in the second half.
-==== SMT ====+==== Surface Mount Devices (SMD) ====
-  * lots of info on SMT boards [[creating_pcbs_with_surface_mount_devices]] +  * lots of info on SMD boards [[creating_pcbs_with_surface_mount_devices]]
-  * use our [[equipment:reflow-oven]] to reflow your SMT boards+  * use our [[equipment:reflow-oven]] to reflow your SMD boards
   * [[making_stencils_in_the_hackspace_using_the_vinyl_cutter]]   * [[making_stencils_in_the_hackspace_using_the_vinyl_cutter]]
   * some interesting techniques used to [[https://www.silabs.com/documents/public/application-notes/an114.pdf|desolder, remove and replace fine pitch QFP devices]]   * some interesting techniques used to [[https://www.silabs.com/documents/public/application-notes/an114.pdf|desolder, remove and replace fine pitch QFP devices]]
   * a range of [[https://entertaininghacks.wordpress.com/library-2/homebrew-pcb-reference-material/|links]] covering many aspects of design, manufacture, assembly, problems/solutions, and reworking   * a range of [[https://entertaininghacks.wordpress.com/library-2/homebrew-pcb-reference-material/|links]] covering many aspects of design, manufacture, assembly, problems/solutions, and reworking
-  * one member's [[https://entertaininghacks.wordpress.com/category/homebrew-pcbs/|experiences]] of designing, making and assembling SMT+PTH PCBs. Summary: easier than expected, and you don't need much special equipment.+  * one member's [[https://entertaininghacks.wordpress.com/category/homebrew-pcbs/|experiences]] of designing, making and assembling SMD+PTH PCBs. Summary: easier than expected, and you don't need much special equipment.
-==== Basic Soldering ====+==== Basic Soldering Techniques & Tutorials ====
-Reliably making good solder joints without damaging the PCB or components isn'difficult, but is much easier if you understand the basic principles. While many videos on youtooob are verbose and a waste of time, there are a few which are informative, succinct and information denseFor soldering, that means describing and showing how to select a tip / temperature / wattagewhere to place the tip and solder, and how to move them - and why +Beginners shouldn'be afraid of soldering, but as with anything it is wise to practise and make mistakes on non-critical componentsIt would be wise to start with thuough hole componentslater move on to SMD components, and leave BGAs to the experts.
-[[https://www.youtube.com/playlist?list=PL926EC0F1F93C1837|Pace Basic Soldering Lessons 1-9]] show good examples of what you should //see// happening when you've got it right - and just as importantly - //wrong//. The only omission is SMD componentspresumably they weren't common when the videos were made.  +Reliably making good solder joints without damaging the PCB or components isn't difficult, but is much easier if you understand the basic principles. While many videos on youtoob are verbose and a waste of time, there are a few which are informative, succinct and information dense. For soldering, that means describing and showing how to select a tip temperature wattagewhere to place the tip and solder, and how to move them - and why.
-But try not to snigger at the pronunciation of "solder"!+[[https://www.youtube.com/playlist?list=PL926EC0F1F93C1837|Pace Basic Soldering Lessons 1-9]] show good examples of what you should //see// happening when you've got it right - and just as importantly - //wrong//. The only omission is SMD components, presumably they weren't common when the videos were made. But try not to snigger at the pronunciation of "solder"!
 +There are a couple of other yootoob channels with soldering tutorials, which seem to have a good reputation: https://www.youtube.com/user/MrMarcSiegel/videos and https://www.youtube.com/user/jkgamm041/videos
 ==== PCB Sources ==== ==== PCB Sources ====
  • resources/pcb
  • Last modified: 11 months ago
