resources:old_electrolytic_capacitors [2016/03/22 21:07]
tggzzz created
resources:old_electrolytic_capacitors [2019/05/09 12:24]
-Hackspace has some bags of old electrolytic capacitors. Electrolytics have a tendency to deteriorate with age; aluminium develops a high ESR or becomes open circuit, and tantalum often develop a short circuit. While the electrolytics currently appear to work OK, it would be unwise to use them for anything "mission citical". They are, however, satisfactory for emergency use, for experimentation, and for prototypes.+===== Old Electrolytic Capacitors =====
-The available values are+Hackspace has some bags of old electrolytic capacitors. Electrolytics have a tendency to deteriorate with age
-  * 10uF 16V, 50V +  * aluminium electrolytics develop a high ESR or becomes open circuit and swell or degass "entertainingly"
-  * 35uF 25V +  * tantalum beads often develop a short circuit, and may crack open to release the magic smoke
-  * 47uF 63V +While the electrolytics currently appear to work OK, it would be unwise to use them for anything "mission citical". They are, however, satisfactory for emergency use, for experimentation, and for prototypes.
-  * 100uF 6.3V16V, 35V +
-  * 220uF 16V +|6.3V|100µF|Aluminium|
-  * 1000uF 35V +|16V|10µF|Aluminium|
-  * 2200uF 25V63V+|16V|10µF|Tantalum bead|
 +|16V|100µF|Aluminium|
 +|16V|220µF|Aluminium|
 +|25V|100µF|Aluminium|
 +|25V|2200µF|Aluminium|
 +|35V|1000µF|Aluminium|
 +|35V|2200µF|Aluminium|
 +|50V|10µF|Aluminium|
 +|63V|47µF|Aluminium|
 +|63V|2200µF|Aluminium|
 Location: crate on shelf near the electronics test bench Location: crate on shelf near the electronics test bench
  • resources/old_electrolytic_capacitors
  • Last modified: 2 years ago
