resources:consumables-hss-jobber-drils [2019/05/12 22:56]
felix.h ↷ Page moved from consumables-hss-jobber-drils to resources:consumables-hss-jobber-drils
— (current)
-=====Hackspace Consumables HSS Jobber Drills=====
-HSS Drills 1mm to 10mm x 0.5mm
-====Location ====
-Spare Drills are kept in the  metal box on the top shelf in G10 at the far end above the woodwork bench.
-The working set is kept in a blue box in the tool cabinets.
-{{::170_hss_drill_box_label.odt|Label for the Spare Drill Box}}
-====Supplier:  UK Drills====
-        [[http://www.ukdrills.comexample.com|]]
-        01942­ 523627
-        UK Drills,
-        24-26 Wigan Road,
-        Hindley.
-        Wigan,
-        WN2 3BE
-====Re-Order Information====
-UK drills charge of postage so add all drills below half the re-order level to you order.
-^Item^UK Drills Supplier Code^Guide Price each £^Purchase Quantity^
-|Drill HSS 1 mm|10.01|0.098|10|
-|Drill HSS 1.5 mm|10.015|0.116|10|
-|Drill HSS 2 mm|10.02|0.125|10|
-|Drill HSS 2.5 mm|10.025|0.132|10|
-|Drill HSS 3 mm|10.03|0.138|10|
-|Drill HSS 3.5 mm|10.035|0.138|10|
-|Drill HSS 4 mm|10.04|0.162|10|
-|Drill HSS 4.5 mm|10.045|0.162|10|
-|Drill HSS 5 mm|10.05|0.198|10|
-|Drill HSS 5.5 mm|10.055|0.251|10|
-|Drill HSS 6 mm|10.06|0.278|10|
-|Drill HSS 6.5 mm|10.065|0.305|10|
-|Drill HSS 7 mm|10.07|0.33|10|
-|Drill HSS 7.5 mm|10.075|0.341|10|
-|Drill HSS 8 mm|10.08|0.438|10|
-|Drill HSS 8.5 mm|10.085|0.503|10|
-|Drill HSS 9 mm|10.09|0.574|10|
-|Drill HSS 9.5 mm|10.095|0.642|10|
-|Drill HSS 10 mm|10.1|0.868|5|
-|Drill HSS 10.5 mm|10.105|0.868|5|
-|Drill HSS 11 mm|10.11|0.98|5|
-|Drill HSS 11.5 mm|10.115|1.02|5|
-|Drill HSS 12 mm|10.12|1.12|5|
-|Drill HSS 12.5 mm|10.125|1.224|5|
-|Drill HSS 13 mm|10.13|1.32|5|
  • resources/consumables-hss-jobber-drils.1557698162
  • Last modified: 2 years ago
