resources:consumables-hss-jobber-drils [2016/03/03 08:47]
johnwillis
resources:consumables-hss-jobber-drils [2019/05/12 22:56]
felix.h ↷ Page moved from consumables-hss-jobber-drils to resources:consumables-hss-jobber-drils
-Hackspace Consumables HSS Jobber Drills+=====Hackspace Consumables HSS Jobber Drills=====
 HSS Drills 1mm to 10mm x 0.5mm HSS Drills 1mm to 10mm x 0.5mm
 +====Location ====
 Spare Drills are kept in the  metal box on the top shelf in G10 at the far end above the woodwork bench. Spare Drills are kept in the  metal box on the top shelf in G10 at the far end above the woodwork bench.
 The working set is kept in a blue box in the tool cabinets.  The working set is kept in a blue box in the tool cabinets.
Line 23: Line 25:
 ====Re-Order Information==== ====Re-Order Information====
 UK drills charge of postage so add all drills below half the re-order level to you order. UK drills charge of postage so add all drills below half the re-order level to you order.
-^Item^UK Drills Supplier Code^Guide Price each^Purchase Quantity^+^Item^UK Drills Supplier Code^Guide Price each £^Purchase Quantity^
 |Drill HSS 1 mm|10.01|0.098|10| |Drill HSS 1 mm|10.01|0.098|10|
 |Drill HSS 1.5 mm|10.015|0.116|10| |Drill HSS 1.5 mm|10.015|0.116|10|
