equipment:sublimation_printer [2019/10/17 22:03]
jmoss
equipment:sublimation_printer [2020/03/12 11:36]
whitecf
 ===== Sublimation Sawgrass SG400 Printer, Virtuoso Print Manager & HP3804 Heat Press ===== ===== Sublimation Sawgrass SG400 Printer, Virtuoso Print Manager & HP3804 Heat Press =====
-{{:​equipment:​printer.jpg?​400|}} +{{:​equipment:​printer.jpg?​300x300|}}
-{{:​equipment:​press.jpg?​400|}} +{{:​equipment:​press.jpg?​300x300|}}
-{{:​equipment:​press1.jpg?​400|}}+{{:​equipment:​press1.jpg?​300x300|}}
 ====Description==== ====Description====
   * The amount of time you press for will also depend on which fabric you are printing on. I found it printed best for between 40 - 55 seconds.   * The amount of time you press for will also depend on which fabric you are printing on. I found it printed best for between 40 - 55 seconds.
   * Pull the handle up. Wait for the fabric to cool for a couple of minutes. Peel off the plastic/​paper.   * Pull the handle up. Wait for the fabric to cool for a couple of minutes. Peel off the plastic/​paper.
-  * REMEMBER: TURN THE HEAD PRESS OFF WHEN FINISHED AND REPLACE BACK ON THE TOOLS & EQUIPMENT SHELF.+  * REMEMBER: TURN THE HEAT PRESS OFF WHEN FINISHED AND REPLACE BACK ON THE TOOLS & EQUIPMENT SHELF.
 This is how my first press turned out! Image on the left is the print, image on the right is the print on fabric (calico): This is how my first press turned out! Image on the left is the print, image on the right is the print on fabric (calico):
Line 41: Line 41:
 ====Hardware==== ====Hardware====
 +[[https://​www.sawgrassink.com/​printers/​sg400|Sawgrass SG400 Printer]]\\
 +{{:​equipment:​virtuoso-user-guide-english.pdf|Printer user manual}}\\
 +[[https://​www.youtube.com/​watch?​v=xFL7tMcWC_4|Video with guidelines on how to use the printer (skip to 1:55)]]
-Sawgrass SG400 Printer: +[[https://​www.youtube.com/​watch?​v=QwDzW-yQARI|Video with guidelines on how to use the heat press]]
-**Link to printer details here** [[https://​www.mdpsupplies.co.uk/​sawgrass-printers-SG400.asp]] +
-**Watch this video for guidelines on how to use the printer (skip to 1:​55)** ​[[https://​www.youtube.com/​watch?​v=xFL7tMcWC_4]] +
-Heat press: +
-**Watch this video for guidelines on how to use the heat press** [[https://​www.youtube.com/​watch?​v=QwDzW-yQARI]]+
 ====Software==== ====Software====
-Details on how to use Virtuoso Print Manager here: [[https://​www.sawgrassink.com/​Products/​Software/​Virtuoso-Print-Manager]].+[[https://​www.sawgrassink.com/​Products/​Software/​Virtuoso-Print-Manager|Sawgrass Virtuoso Print Manager]]
  • equipment/sublimation_printer
  • Last modified: 4 months ago
  • by whitecf
