equipment:snagging_list [2019/05/16 12:23]
russell Adding dismantling guide link
equipment:snagging_list [2020/02/19 16:58]
russell
Line 22: Line 22:
 | Access Control |  YES| Maybe just padlock? | Card system incomplete |   | | Access Control |  YES| Maybe just padlock? | Card system incomplete |   |
 | Locating Rotary Converter |NO  | Mount on wall? | Heavy, Use rubber isolation mounts |   | | Locating Rotary Converter |NO  | Mount on wall? | Heavy, Use rubber isolation mounts |   |
 +| Handwheel Pinion Shaft | YES | Knurled and unrepairable | Obsolete part | Replaced |
 | E Stop switch |  ??  | Knee or foot control |  |   | | E Stop switch |  ??  | Knee or foot control |  |   |
-| Oil leak from Carriage Apron |  YES|  | Large leak - Weekend Job |   ​|+| Oil leak from Carriage Apron |  YES|  | Large leak - Weekend Job | Fixed |
 | Oil on drive belts |  ??  | Find leak + Clean belts |  |  | | Oil on drive belts |  ??  | Find leak + Clean belts |  |  |
 | Shaft seals on exposed Headstock |  ??  |  | Oil on drive belts |  | | Shaft seals on exposed Headstock |  ??  |  | Oil on drive belts |  |
-| Dust Cover |  ​??  ​| ​ | Dust on machine ​ |+| Dust Cover |  ​No  ​| ​ | Dust cover made Completed ​|
 | Clean + Degrease Lathe |NO  |  |  |  | | Clean + Degrease Lathe |NO  |  |  |  |
 | Count Gear Cutting Gears |NO  | All listed as standard are present | Suspecting one is missing | DONE | | Count Gear Cutting Gears |NO  | All listed as standard are present | Suspecting one is missing | DONE |
Line 35: Line 36:
 | Level lathe |NO  | Needs to be level to take twist out of bed | Need accurate level |  |  | Level lathe |NO  | Needs to be level to take twist out of bed | Need accurate level |  |
 | Realign / setup encoders |  YES| Need configuring |  |  |  | Realign / setup encoders |  YES| Need configuring |  |  |
-| Crosslide Lead screw Nuts |NO  | These are worn | PN 905008 ​  +| Crosslide Lead screw Nuts |NO  | These are worn | PN 905008 ​or fix backlash adjuster ​Parts ordered Needs assembling ​
Line 47: Line 48:
 [[https://​www.mig-welding.co.uk/​forum/​threads/​harrison-m300-dismantling-advice.69886/​|Harrison M300 dismantling advice]]\\ [[https://​www.mig-welding.co.uk/​forum/​threads/​harrison-m300-dismantling-advice.69886/​|Harrison M300 dismantling advice]]\\
 +Carriage saddle gearbox is mucky and needs cleaning internally before reassembly.  ​
 =====OLD NOTES===== =====OLD NOTES=====
 Kept as ongoing reference during the full commissioning process. ​ Kept as ongoing reference during the full commissioning process. ​
  • equipment/snagging_list
  • Last modified: 5 months ago
  • by russell
