equipment:prusamk3 [2020/07/25 13:36]
equipment:prusamk3 [2021/07/27 18:38] (current)
jonnyt
Line 22: Line 22:
 Nick G\\ Nick G\\
 Sam C\\ Sam C\\
 +Fraser H
 ===== Filament ===== ===== Filament =====
Line 37: Line 37:
 ===== Software ====== ===== Software ======
-The computer at the Hackspace with PrusaSlicer on has some issuesso you may find it is more time-efficient to slice files on your own computer. Download the latest version of PrusaSlicer [[https://www.prusa3d.com/drivers/ | here]]. Make sure you select the options for Original Prusa MK3S with a 0.4mm nozzle when you install and start up the software for the first time.+The computer at the Hackspace has the latest version PrusaSlicer (2.3.3) on, however you may find it is more time-efficient to slice files on your own computer. Download the latest version of PrusaSlicer [[https://www.prusa3d.com/drivers/ | here]]. Make sure you select the options for Original Prusa MK3S with a 0.4mm nozzle when you install and start-up the software for the first time.
 **Only use the default Printer Settings in PrusaSlicer.** You are welcome to tweak Filament Settings and it is in your best interests to change Print Settings for every print. If you save your settings on the Hackspace computer, put your initials at the beginning, e.g. "NG 0.3mm Layers Super Quick". **Only use the default Printer Settings in PrusaSlicer.** You are welcome to tweak Filament Settings and it is in your best interests to change Print Settings for every print. If you save your settings on the Hackspace computer, put your initials at the beginning, e.g. "NG 0.3mm Layers Super Quick".
  • equipment/prusamk3.1595680572
  • Last modified: 16 months ago
  • by nick_gover
