equipment:oscilloscopes [2017/05/03 10:33]
equipment:oscilloscopes [2020/10/24 11:16] (current)
-This page summarises our scopes in terms of their target application domains, who might use them, and where they can be stored. The "details" section lists unique benefits. From this we can choose which scopes to cull, and to see what would be interesting in the future.  +Since the oscilloscope and probe become part of the circuit being testedit is also necessary to understand //and apply// the information on the [[equipment:oscilloscopeprobes|oscilloscope probes]] page. If in doubt (especially about safety), **please ask before damaging scopes or people**.
-  * dispose, because poor quality or too many duplicates or slightly faulty +
-Oscilloscopes are useless on their own - they also need probes to connect to the circuit. //Probes are surprisingly fragile and significantly affect your measurements// - see the [[oscilloscopeprobes|Oscilloscope Probe]] page for more informationNote than //none// of the HackSpace probes are suitable for measuring mains voltages directly.+
- +**Oscilloscopes can be used dangerously**, especially when connecting to anything connected to the mains voltages, and it is easy for a beginner to make a subtle mistake. **Getting it wrong can result in __loud__ noises followed by __deathly__ slience**.
-Oscilloscopes can be used dangerously, especially when connecting to anything connected to the mains voltages. **Getting it wrong can result in __loud__ noises followed by __deathly__ slience**.     Obviously **electrocution** is a potential danger, but incorrect connections can also **melt** scope probes, cause **fires**, as well as **destroying** the **scope** or **unit** being tested. You may be surprised how mains earths can and do cause those problems. Internally scopes contain >**8kV**, and they can retain the charge long after the scope is switched off.+  * obviously **electrocution** is a potential danger, but incorrect connections can also **melt** scope probes, cause **fires**, as well as **destroying** the **scope** or **unit** being tested.
 +  * you may be surprised how mains earths can and do cause those problems.
 +  * internally scopes contain >**8kV**, and they can retain the charge long after the scope is switched off.
 Read and understand the references in the 'Formal' and 'Praxis' sections of [[https://entertaininghacks.wordpress.com/library-2/scope-probe-reference-material/|this page]], and [[http://www.tek.com/document/primer/abcs-probes|Tektronix' ABCs of Probes Primer]] pp55-56 - and apply the knowledge //before// you make a connection.  Read and understand the references in the 'Formal' and 'Praxis' sections of [[https://entertaininghacks.wordpress.com/library-2/scope-probe-reference-material/|this page]], and [[http://www.tek.com/document/primer/abcs-probes|Tektronix' ABCs of Probes Primer]] pp55-56 - and apply the knowledge //before// you make a connection.
Line 42: Line 32:
 +One way of categorising scopes is by how often we expect to use them, which translates into where they should be stored //(this will be updated after the move)//:
Line 50: Line 56:
-^Audio |Kenwood CS4125 |Telequipment DM63 |Metrotest OX8020 | |<100kHz, mV - audio signals, sensors | +^Audio |Kenwood CS4125 | |Metrotest OX8020 | |<100kHz, mV - audio signals, sensors |
-^Mechatronics |Kenwood CS4125 |Topward 7042 |Metrotest OX8020 |Wavetek 9020 |<10MHz, 50mV-50V, - motors, actuators, machines | +^Mechatronics |Kenwood CS4125 | |Metrotest OX8020 | |<10MHz, 50mV-50V, - motors, actuators, machines |
-^::: |Agilent 54621 |Telequipment DM63 |Hameg HM203 |Gould OS300 |::: | +^::: |Agilent 54621 | | | |::: |
-^Digital |Agilent 54621 |Telequipment DM63 | |Tektronix TDS340 |%%<=%%60MHz, 500mV-5V, - well-behaved logic e.g. Arduino +^Digital |Agilent 54621 |IsoTech ISR-1014  | |%%<=%%60MHz, 500mV-5V, - well-behaved logic e.g. Arduino |
-^::: | |Topward 7042 | |Schlumberger 5602.C |::: +^::: | |Tektronix 2245 | | |::: |
-^::: | |Tektronix 2445  | | |::: | +^Signal Integrity | |Tektronix 2245 | | |>=100MHz, 500mV-5V, medium-speed logic and checking valid logic levels, e.g. generic TTL, CMOS|
-^Signal Integrity | |Tektronix 2245 | |Tektronix TDS340 |>=100MHz, 500mV-5V, medium-speed logic and checking valid logic levels, e.g. generic TTL, CMOS| +^::: | |IsoTech ISR-1014 | | |::: |
-^::: | | | |Schlumberger 5602.C |::: |+
Line 65: Line 70:
 === Location: Electronics Test Bench === === Location: Electronics Test Bench ===
-| ^Kenwood CS4125 ^Agilent 54621 ^Tektronix 2245 +| ^Kenwood CS4125 ^Agilent 54621 ^
-^Location |Test bench, since small and lightweight |Test bench, since small and lightweight |Test bench, our most capable scope +^Location |Test bench, since small and lightweight |Test bench, since small and lightweight |
-^Domain |Audio, mechatronics |Digital, mechatronics |Medium speed digital, signal integrity +^Domain |Audio, mechatronics |Digital, mechatronics |
-^Specification |20MHz, **1mV/div**, analogue |60MHz, 10mV/div, digital |100MHz, analogue4 channel +^Specification |20MHz, **1mV/div**, analogue |60MHz, 10mV/div, digital, OSD
-^::: | |IEEE-488 interface |Autosetup +^::: | |IEEE-488 interface |
-^::: | |Waveform capture/measurements |Manual time/freq/voltage measurements | +^::: | |Waveform capture/measurements |
-^Condition |Excellent – **everything just works** |Fully functional  |Fully functional +^Condition |Excellent – **everything just works** |Fully functional
-^::: |Good standard controls |Floppy inaccessible, repair unknown |Plan on replacing X/Y mains capacitors plus electrolytics +^::: |Good standard controls |Floppy inaccessible, repair unknown |
-^::: | |Adequate UI |Probably need to replace calibration battery +^::: | |Adequate UI |
-^Comments |**First choice** low-end scope |**First choice** digital scope |**First choice** fast scope | +^Comments |**First choice** low-end scope |**First choice** digital scope |
-^::: |**Excellent for casual use** |UI makes it less suitable for casual use | Move "soft knobs" in both directions, including after autosetup +^::: |**Excellent for casual use** |UI makes it less suitable for casual use |
-^::: |Most sensitive scope |Potential printout via IEEE-488 or floppy +^::: |Most sensitive scope |Potential printout via IEEE-488 or floppy |
-^::: |See also Metrotest, Topward | | +^::: |See also Metrotest, Topward | |
-^USP |Small, easy, sensitive |Small, easy, fast |Fast, 4 channels, standard controls, not big +^USP |Small, easy, sensitive |Small, easy, fast |
-^    |{{ :oscilloscope:kenwood-cs4124.jpg?direct&100 |}}|{{ :oscilloscope:agilent-54621a.jpg?direct&100 |}} |{{ :oscilloscope:tektronix2245.jpg?direct&100 |}} |+^    |{{ :oscilloscope:kenwood-cs4124.jpg?direct&100 |}}|{{ :oscilloscope:agilent-54621a.jpg?direct&100 |}} |
-| ^Schlumberger 5602.C ^Topward 7042 ^Telequipment DM63 +| ^IsoTech ISR-1014 ^Tektronix 2245
-^Location |**Floor** under test bench, on end |Test bench shelf | Test bench shelf | +^Location |Test bench shelf|Test bench shelf, to reduce chance of accidental damage
-^Domain |Medium speed digital, signal integrity |Digitalmechatronics, when Kenwood CS4215 insufficient |Sensitive audio, mechatronics, isolated events +^Domain |Medium speed digital, signal integrity |Medium speed digitalsignal integrity
-^Specification |100MHz, 10mV/divdigital |**40MHz**, 5mV/div, analogue |50MHz, **1mV/div** | +^Specification |100MHz, analogue, **4 channel**, OSD |100MHz, analogue, **4 channel**, OSD
-^::: |IEEE488 interface |**Dual timebase** |**Three channel**, **dual beam** +^::: |Autosetup |Autosetup
-^::: |Waveform capture/measurements |Standard controls |**Analogue storage** +^::: |Manual time/freq/voltage measurements|Manual time/freq/voltage measurements
-^Condition |Fully functional |Excellent – **everything just works** as expected |Fully functional | +^Condition |Fully functional|Fully functional |
-^::: |**Appalling UI** |Probably benefit from calibration and checking capacitors | +^::: | |Plan on replacing X/Y mains capacitors plus electrolytics
-^::: |Heavy, big, cannot keep on high/weak shelf | | | +^::: | |May need to replace calibration battery
-^Comments |The **highest speed scope**|**Excellent scope** |**Sensitive**, **three** channels, good for **transient events** | +^Comments |**First choice** fast scope |**First choice** fast scope
-^::: | Not for casual use  |**Service and operation manual** |Only analogue storage scopetraditionally less convenient than digital storage +^::: |Equivalent to the Tek 2245, but softbutton menus slightly less suitable for casual use |Move "soft knobs" in both directionsincluding after autosetup
-^::: |Potential printout via IEEE-488 |Lightweight | **Extender cards and manuals** for maintenance +^::: |Small size/weight |Medium size/weight
-^::: | |See also Kenwood, Metrotest |Dual beams very rare +^::: | |**OUT OF ACTION**. //Do NOT use//. An unknown person "floated" this scope by disconnecting the protective mains earth. Apart from being **lethally dangerous** [[oscilloscopes#safety|as noted above]], it may have been damaged internally. It has been PAT tested, but must be disassembled and the PSU capacitors checked and/or replaced by a person skilled in that task.
-^USP |100MHz |Smallmedium speed, easy Sensitivethree channelstorage +^USP |Fast4 channels |Fast4 channelsexcellent triggering, standard controls
-   |{{ :oscilloscope:schlumberger-5602c.jpg?direct&100 |}} |{{ :oscilloscope:topward-7042.jpg?direct&100 |}} |{{ :oscilloscope:telequipmentDM63.jpg?direct&100 |}} |+  |{{ :oscilloscope:isotech-isr1014.jpg?direct&100 |}} |{{ :oscilloscope:tektronix2245.jpg?direct&100 |}}  |
-^Hameg HM203 ^Metrotest OX8020 ^ +| ^Metrotest OX8020 ^
-^Location |High shelf, for use during workshops |High shelf, for when Kenwood CS4215 insufficient |  +^Location |High shelf, for when Kenwood CS4215 insufficient |
-^Domain |Audio, mechatronics |Audio, mechatronics | +^Domain |Audio, mechatronics |
-^Specification |20MHz, 5mV/div, analogue |20MHz, **1mV/div**, hybrid analogue/digital +^Specification |20MHz, **1mV/div**, hybrid analogue/digital
-^::: |Dual timebase | +^::: |Dual timebase |
-^::: |Limited DSO features | +^::: |Limited DSO features |
-^::: |Manual voltage and time cursors | +^::: |Manual voltage and time cursors |
-^::: |Prints HPGL/HP-PCL to centronics/serial | +^::: |Prints HPGL/HP-PCL to centronics/serial |
-^Condition |Mainly functional, works nicely |Fully functional | +^Condition |Fully functional |
-^::: |Poor or strange controls |**UI a little odd**; dim lights indicate important settings +^::: |**UI a little odd**; dim lights indicate important settings |
-^::: |X-shift knob missing | +^Comments |**On loan** from Lee Wiltshire
-^Comments |OK, unremarkable |**On loan** from Lee Wiltshire +^::: |Similar to Kenwood CS4215, Topward 7042  |
-^::: |Similar to Kenwood CS4215, Topward 7042  | +^::: |Would be best low-end scope, except for awkward UI |
-^::: |Would be best low-end scope, except for awkward UI | +^USP |Sensitive, printing |
-^USP |Nothing => candidate for disposal |Sensitive, printing |  +^    | {{ :oscilloscope:metrotest-ox8020.jpg?direct&100 |}}|
-^    | {{ :oscilloscope:hameg-hm203.jpg?direct&100 |}}| {{ :oscilloscope:metrotest-ox8020.jpg?direct&100 |}}| +
-| ^ Wavetek 9020 ^Gould OS300 ^Tek TDS340 +Since they were either faulty or a pain to use, and we had better scopes with these features, in February 2019 we disposed of these scopes: Wavetek 9020Gould OS300Tek TDS340, Schlumberger 5602.CHameg HM203.
-^Location |Dispose |Disposefor use  |Dispose | +
-^Domain |Generalaudio, mechatronics |General, audio, mechatronics |Digital, signal integrity | +To make more room and to reduce the equipment that needed to be moved to the new premises, in October 2020 we disposed of the Tektronix DM63 and the Topward 7042.
-^Specification |20MHz, 5mV/div, analogue |20MHz, 2mV/div, analogue |100MHz, 1V/div, digital | +
-^::: |Dual timebase | |Display saved on floppy | +If you want to see their featureslook at an earlier revision of this page.
-^Condition |Some ringing on digital transition |Some ringing on digital transition |Ch1 broken | +
-^::: |Some channel crosstalk |Some channel crosstalk |Ch2 only 1V/div and above | +==== Current Scope Location ====
-^::: |Trigger on -ve slope broken |External trig broken |Adequate UI | +
-^::: |Delayed timebase noisy | | +(this will be updated after the move)
-^::: |Ch1Ch2 uncal switch noisy | | +
-^::: |Vert mode controls quirky | | +
-^::: |Poor but could be functional |Usable for simple purposes | +
-^Comments |Adequate low-end scope |Adequate low-end scope |Higher speed, screen capture | +
-^::: |Repair required |Usable without external trig |Repair required, hybrids unobtanium | +
-^::: | |Lightweight |{{ :oscilloscope:tektronix-tds340.jpg?direct&100 |}} |+
  • equipment/oscilloscopes.1493804016
  • Last modified: 5 years ago
