equipment:oscilloscopes [2017/05/03 11:27]
equipment:oscilloscopes [2020/05/30 11:17]
-This page summarises our scopes in terms of their target application domains, who might use them, and where they can be stored. The "details" section lists unique benefits. From this we can choose which scopes to cull, and to see what would be interesting in the future.  +Since the oscilloscope and probe become part of the circuit being testedit is also necessary to understand //and apply// the information on the [[equipment:oscilloscopeprobes|oscilloscope probes]] page. If in doubt (especially about safety), please ask before damaging scopes or people.
-  * dispose, because poor quality or too many duplicates or slightly faulty +
-Oscilloscopes are useless on their own - they also need probes to connect to the circuit. //Probes are surprisingly fragile and significantly affect your measurements// - see the [[oscilloscopeprobes|Oscilloscope Probe]] page for more informationNote than //none// of the HackSpace probes are suitable for measuring mains voltages directly.+
Line 42: Line 29:
 +One way of categorising scopes is by how often we expect to use them, which translates into where they should be stored:
Line 51: Line 54:
 ^Audio |Kenwood CS4125 |Telequipment DM63 |Metrotest OX8020 | |<100kHz, mV - audio signals, sensors | ^Audio |Kenwood CS4125 |Telequipment DM63 |Metrotest OX8020 | |<100kHz, mV - audio signals, sensors |
-^Mechatronics |Kenwood CS4125 |Telequipment DM63 |Metrotest OX8020 |Wavetek 9020 |<10MHz, 50mV-50V, - motors, actuators, machines | +^Mechatronics |Kenwood CS4125 |Telequipment DM63 |Metrotest OX8020 | |<10MHz, 50mV-50V, - motors, actuators, machines |
-^::: |Agilent 54621 | |Topward 7042 |Gould OS300 |::: | +^::: |Agilent 54621 | |Topward 7042 | |::: |
-^::: | | | |Hameg HM203 |::: | +^Digital |Agilent 54621 |Telequipment DM63 |Topward 7042  | |%%<=%%60MHz, 500mV-5V, - well-behaved logic e.g. Arduino |
-^Digital |Agilent 54621 |Telequipment DM63 |Topward 7042  |Tektronix TDS340 |%%<=%%60MHz, 500mV-5V, - well-behaved logic e.g. Arduino | +^::: | |Tektronix 2245 | | |::: |
-^::: | |Tektronix 2445 | |Schlumberger 5602.C |::: | +^::: | |IsoTech ISR-1014 | | |::: |
-^Signal Integrity | |Tektronix 2245 | |Tektronix TDS340 |>=100MHz, 500mV-5V, medium-speed logic and checking valid logic levels, e.g. generic TTL, CMOS| +^Signal Integrity | |Tektronix 2245 | | |>=100MHz, 500mV-5V, medium-speed logic and checking valid logic levels, e.g. generic TTL, CMOS|
-^::: | | | |Schlumberger 5602.C |::: |+^::: | |IsoTech ISR-1014 | | |::: |
Line 65: Line 68:
 === Location: Electronics Test Bench === === Location: Electronics Test Bench ===
-| ^Kenwood CS4125 ^Agilent 54621 ^Tektronix 2245 +| ^Kenwood CS4125 ^Agilent 54621 ^
-^Location |Test bench, since small and lightweight |Test bench, since small and lightweight |Test bench, our most capable scope +^Location |Test bench, since small and lightweight |Test bench, since small and lightweight |
-^Domain |Audio, mechatronics |Digital, mechatronics |Medium speed digital, signal integrity +^Domain |Audio, mechatronics |Digital, mechatronics |
-^Specification |20MHz, **1mV/div**, analogue |60MHz, 10mV/div, digital |100MHz, analogue4 channel +^Specification |20MHz, **1mV/div**, analogue |60MHz, 10mV/div, digital, OSD
-^::: | |IEEE-488 interface |Autosetup +^::: | |IEEE-488 interface |
-^::: | |Waveform capture/measurements |Manual time/freq/voltage measurements | +^::: | |Waveform capture/measurements |
-^Condition |Excellent – **everything just works** |Fully functional  |Fully functional +^Condition |Excellent – **everything just works** |Fully functional
-^::: |Good standard controls |Floppy inaccessible, repair unknown |Plan on replacing X/Y mains capacitors plus electrolytics +^::: |Good standard controls |Floppy inaccessible, repair unknown |
-^::: | |Adequate UI |Probably need to replace calibration battery +^::: | |Adequate UI |
-^Comments |**First choice** low-end scope |**First choice** digital scope |**First choice** fast scope | +^Comments |**First choice** low-end scope |**First choice** digital scope |
-^::: |**Excellent for casual use** |UI makes it less suitable for casual use | Move "soft knobs" in both directions, including after autosetup +^::: |**Excellent for casual use** |UI makes it less suitable for casual use |
-^::: |Most sensitive scope |Potential printout via IEEE-488 or floppy +^::: |Most sensitive scope |Potential printout via IEEE-488 or floppy |
-^::: |See also Metrotest, Topward | | +^::: |See also Metrotest, Topward | |
-^USP |Small, easy, sensitive |Small, easy, fast |Fast, 4 channels, standard controls, not big +^USP |Small, easy, sensitive |Small, easy, fast |
-^    |{{ :oscilloscope:kenwood-cs4124.jpg?direct&100 |}}|{{ :oscilloscope:agilent-54621a.jpg?direct&100 |}} |{{ :oscilloscope:tektronix2245.jpg?direct&100 |}} |+^    |{{ :oscilloscope:kenwood-cs4124.jpg?direct&100 |}}|{{ :oscilloscope:agilent-54621a.jpg?direct&100 |}} |
-| ^xTopward 7042 ^Telequipment DM63 ^ +| ^IsoTech ISR-1014 ^Tektronix 2245 ^Telequipment DM63 ^
-^Location |xTest bench shelf | Test bench shelf | +^Location |Test bench shelf|Test bench shelf, to reduce chance of accidental damage  | Test bench shelf |
-^Domain |xDigitalmechatronicswhen Kenwood CS4215 insufficient |Sensitive audio, mechatronics, isolated events | +^Domain |Medium speed digitalsignal integrity |Medium speed digitalsignal integrity |Sensitive audio, mechatronics, isolated events |
-^Specification |x**40MHz**, 5mV/div, analogue |50MHz, **1mV/div** | +^Specification |100MHz, analogue, **4 channel**, OSD |100MHz, analogue, **4 channel**, OSD |50MHz, **1mV/div** |
-^::: |x**Dual timebase** |**Three channel**, **dual beam** | +^::: |Autosetup |Autosetup |**Three channel**, **dual beam** |
-^::: |xStandard controls |**Analogue storage** | +^::: |Manual time/freq/voltage measurements|Manual time/freq/voltage measurements |**Analogue storage** |
-^Condition |xExcellent – **everything just works** as expected |Fully functional | +^Condition |Fully functional|Fully functional |Functional, but triggering needs tewaking
-^::: | |Probably benefit from calibration and checking capacitors | +^::: | |Plan on replacing X/Y mains capacitors plus electrolytics |Probably benefit from calibration and checking capacitors |
-^::: | | | +^::: | |May need to replace calibration battery |**Needs a PSU recap** for 100Hz display intensity ripple
-^Comments |x**Excellent scope** |**Sensitive**, **three** channels, good for **transient events** | +^Comments |**First choice** fast scope |**First choice** fast scope |**Sensitive**, **three** channels, good for **transient events** |
-^::: | x**Service and operation manual** |Only analogue storage scope, traditionally less convenient than digital storage | +^::: |Equivalent to the Tek 2245, but softbutton menus slightly less suitable for casual use |Move "soft knobs" in both directions, including after autosetup |Only analogue storage scope, traditionally less convenient than digital storage |
-^::: |xLightweight | **Extender cards and manuals** for maintenance | +^::: |Small size/weight |Medium size/weight | **Extender cards and manuals** for maintenance |
-^::: |See also KenwoodMetrotest |Dual beams very rare | +^::: | |**OUT OF ACTION**. //Do NOT use//. An unknown person "floated" this scope by disconnecting the protective mains earth. Apart from being **lethally dangerous** [[oscilloscopes#safety|as noted above]]it may have been damaged internally. It has been PAT tested, but must be disassembled and the PSU capacitors checked and/or replaced by a person skilled in that task. |Dual beams very rare |
-^USP |xSmallmedium speedeasy | Sensitive, three channel, storage | +^USP |Fast4 channels |Fast4 channels, excellent triggering, standard controls | Sensitive, three channel, storage |
-   |{{ :oscilloscope:topward-7042.jpg?direct&100 |}} |{{ :oscilloscope:telequipmentDM63.jpg?direct&100 |}} |+  |{{ :oscilloscope:isotech-isr1014.jpg?direct&100 |}} |{{ :oscilloscope:tektronix2245.jpg?direct&100 |}}  |{{ :oscilloscope:telequipmentDM63.jpg?direct&100 |}} |
Line 116: Line 119:
 ^USP |Small, medium speed, easy |Sensitive, printing |  ^USP |Small, medium speed, easy |Sensitive, printing |
 ^    |{{ :oscilloscope:topward-7042.jpg?direct&100 |}} | {{ :oscilloscope:metrotest-ox8020.jpg?direct&100 |}}| ^    |{{ :oscilloscope:topward-7042.jpg?direct&100 |}} | {{ :oscilloscope:metrotest-ox8020.jpg?direct&100 |}}|
-| ^ Wavetek 9020 ^Gould OS300 ^Tek TDS340 ^Schlumberger 5602.C ^Hameg HM203 ^ +Since they were either faulty or a pain to use, and we had better scopes with these features, in February 2019 we disposed of these scopes: Wavetek 9020Gould OS300Tek TDS340Schlumberger 5602.CHameg HM203
-^Location |Dispose |Dispose, for use  |Dispose | Dispose for masochist's use |Dispose, for use | +
-^Domain |Generalaudio, mechatronics |General, audio, mechatronics |Digital, signal integrity |Medium speed digital, signal integrity |Audio, mechatronics | +If you want to see their featureslook at an earlier revision of this page.
-^Specification |20MHz, 5mV/div, analogue |20MHz, 2mV/div, analogue |100MHz, 1V/div, digital |100MHz, 10mV/div, digital |20MHz, 5mV/div, analogue | +
-^::: |Dual timebase | |Display saved on floppy | Waveform capture/measurements, IEEE488 interface | | +==== Current Scope Location ====
-^Condition |Some ringing on digital transition |Some ringing on digital transition |Ch1 broken |Fully functional |Mainly functional, works nicely | +
-^::: |Some channel crosstalk |Some channel crosstalk |Ch2 only 1V/div and above | |Poor or strange controls | +
-^::: |Trigger on -ve slope broken |External trig broken |Adequate UI | |X-shift knob missing | +
-^::: |Delayed timebase noisy | | | | +
-^::: |Ch1, Ch2 uncal switch noisy | | | | +
-^::: |Vert mode controls quirky | | | | +
-^::: |Poor but could be functional |Usable for simple purposes | | | | +
-^Comments |Adequate low-end scope |Adequate low-end scope |Higher speed, screen capture |**Appalling UI**, not for casual use |OK, unremarkable | +
-^::: |Repair required |Usable without external trig |Repair required, hybrids unobtanium |High speed, heavy  | | +
-^::: | |Lightweight |{{ :oscilloscope:tektronix-tds340.jpg?direct&100 |}} |{{ :oscilloscope:schlumberger-5602c.jpg?direct&100 |}} | {{ :oscilloscope:hameg-hm203.jpg?direct&100 |}}|+
  • Last modified: 13 months ago
