equipment:oscilloscopes [2017/02/09 14:42]
-==== Oscilloscopes ==== +===== Oscilloscopes =====
-=== Overview === +
-Understand how to use them safely //before// using them.+
-This page summarises our scopes in terms of their target application domains, who might use them, and where they can be stored. The "details" section lists unique benefits. From this we can choose which scopes to cull, and to see what would be interesting in the future.  +Since the oscilloscope and probe become part of the circuit being testedit is also necessary to understand //and apply// the information on the [[equipment:oscilloscopeprobes|oscilloscope probes]] page. If in doubt (especially about safety), please ask before damaging scopes or people.
-  * dispose, because poor quality or too many duplicates or slightly faulty +
-Oscilloscopes are useless on their own - they also need probes to connect to the circuit. //Probes are surprisingly fragile and significantly affect your measurements// - see the [[oscilloscopeprobes|Oscilloscope Probe]] page for more informationNote than //none// of the HackSpace probes are suitable for measuring mains voltages directly. +
-===Safety===+
 +====Safety====
Line 42: Line 29:
-===Using Our Oscilloscopes===+One way of categorising scopes is by how often we expect to use them, which translates into where they should be stored:
 +====Using Our Oscilloscopes====
-^Audio |Kenwood CS4125 | |Metrotest OX8020 | |<100kHz, mV - audio signals, sensors | +^Audio |Kenwood CS4125 |Telequipment DM63 |Metrotest OX8020 | |<100kHz, mV - audio signals, sensors |
-^Mechatronics |Kenwood CS4125 |Topward 7042 |Metrotest OX8020 |Wavetek 9020 |<10MHz, 50mV-50V, - motors, actuators, machines | +^Mechatronics |Kenwood CS4125 |Telequipment DM63 |Metrotest OX8020 | |<10MHz, 50mV-50V, - motors, actuators, machines |
-^::: |Agilent 54621 | |Hameg HM203 |Gould OS300 |::: | +^::: |Agilent 54621 | |Topward 7042 | |::: |
-^Digital |Agilent 54621 |Schlumberger 5602.C |Tektronix TDS340 | |%%<=%%60MHz, 500mV-5V, - well-behaved logic e.g. Arduino | +^Digital |Agilent 54621 |Telequipment DM63 |Topward 7042  | |%%<=%%60MHz, 500mV-5V, - well-behaved logic e.g. Arduino |
-^::: | |Topward 7042 | | |::: | +^::: | |Tektronix 2245 | | |::: |
-^Signal Integrity | |Schlumberger 5602.C |Tektronix TDS340 | |>=100MHz, 500mV-5V, medium-speed logic and checking valid logic levels, e.g. generic TTL, CMOS|+^::: | |IsoTech ISR-1014 | | |::: |
 +^Signal Integrity | |Tektronix 2245 | | |>=100MHz, 500mV-5V, medium-speed logic and checking valid logic levels, e.g. generic TTL, CMOS
-=== Details ===+==== Specific Features ====
 Important features indicated by **emphasis**. Important features indicated by **emphasis**.
-== Electronics Test Bench ==+=== Location: Electronics Test Bench ===
 | ^Kenwood CS4125 ^Agilent 54621 ^ | ^Kenwood CS4125 ^Agilent 54621 ^
Line 79: Line 84:
 ^    |{{ :oscilloscope:kenwood-cs4124.jpg?direct&100 |}}|{{ :oscilloscope:agilent-54621a.jpg?direct&100 |}} | ^    |{{ :oscilloscope:kenwood-cs4124.jpg?direct&100 |}}|{{ :oscilloscope:agilent-54621a.jpg?direct&100 |}} |
-== Accessible Shelf Above Test Bench== +=== Location: Accessible Shelf Above Test Bench===
-| ^Schlumberger 5602.C ^Topward 7042 +| ^IsoTech ISR-1014 ^Tektronix 2245 ^Telequipment DM63
-^Location |**Floor** under test bench, on end, for high speed measurement |Test bench shelf, for when Kenwood CS4215 insufficient |  +^Location |Test bench shelf|Test bench shelf, to reduce chance of accidental damage  | Test bench shelf
-^Domain |Medium speed digital, signal integrity |Digital, mechatronics | +^Domain |Medium speed digital, signal integrity |Medium speed digital, signal integrity |Sensitive audio, mechatronics, isolated events
-^Specification |100MHz, 10mV/divdigital |**40MHz**, 5mV/div, analogue +^Specification |100MHz, analogue**4 channel**, OSD |100MHz, analogue, **4 channel**, OSD |50MHz, **1mV/div**
-^::: |IEEE488 interface |**Dual timebase** | +^::: |Autosetup |Autosetup |**Three channel**, **dual beam** |
-^::: |Waveform capture/measurements |Standard controls +^::: |Manual time/freq/voltage measurements|Manual time/freq/voltage measurements |**Analogue storage**
-^Condition |Fully functional |Excellent – **everything just works** as expected +^Condition |Fully functional|Fully functional |Functional, but triggering needs tewaking |
-^::: |**Appalling UI** +^::: | |Plan on replacing X/Y mains capacitors plus electrolytics |Probably benefit from calibration and checking capacitors |
-^::: |Heavybigcannot keep on high/weak shelf | | +^::: | |May need to replace calibration battery |**Needs a PSU recap** for 100Hz display intensity ripple |
-^Comments |The **highest speed scope**|**Excellent scope** | +^Comments |**First choice** fast scope |**First choice** fast scope |**Sensitive**, **three** channels, good for **transient events** |
-^::: | Not for casual use  |**Service and operation manual** | +^::: |Equivalent to the Tek 2245, but softbutton menus slightly less suitable for casual use |Move "soft knobs" in both directions, including after autosetup |Only analogue storage scope, traditionally less convenient than digital storage |
-^::: |Potential printout via IEEE-488 |Lightweight | +^::: |Small size/weight |Medium size/weight | **Extender cards and manuals** for maintenance
-^::: |See also Kenwood, Metrotest | +^::: | |**OUT OF ACTION**. //Do NOT use//. An unknown person "floated" this scope by disconnecting the protective mains earth. Apart from being **lethally dangerous** [[oscilloscopes#safety|as noted above]]it may have been damaged internally. It has been PAT testedbut must be disassembled and the PSU capacitors checked and/or replaced by a person skilled in that task. |Dual beams very rare |
-^USP |100MHz |Small, medium speed, easy | +^USP |Fast, 4 channels |Fast, 4 channels, excellent triggering, standard controls | Sensitive, three channel, storage |
-^    |{{ :oscilloscope:schlumberger-5602c.jpg?direct&100 |}} |{{ :oscilloscope:topward-7042.jpg?direct&100 |}} |+^   |{{ :oscilloscope:isotech-isr1014.jpg?direct&100 |}} |{{ :oscilloscope:tektronix2245.jpg?direct&100 |}}  |{{ :oscilloscope:telequipmentDM63.jpg?direct&100 |}} |
 +=== Location: High Shelf ===
 +| ^Topward 7042 ^Metrotest OX8020 ^
 +^Location |High shelf, for use during workshops |High shelf, for when Kenwood CS4215 insufficient |
 +^Domain |Digital, mechatronics, when Kenwood CS4215 insufficient |Audio, mechatronics |
 +^Specification |**40MHz**, 5mV/div, analogue  |20MHz, **1mV/div**, hybrid analogue/digital
 +^::: |**Dual timebase** |Dual timebase |
 +^::: |Standard controls |Limited DSO features |
 +^::: | |Manual voltage and time cursors |
 +^::: | |Prints HPGL/HP-PCL to centronics/serial |
 +^Condition |Excellent – **everything just works** as expected |Fully functional
 +^::: | |**UI a little odd**; dim lights indicate important settings |
 +^Comments |**Excellent scope** |**On loan** from Lee Wiltshire
 +^::: |**Service and operation manual** |Similar to Kenwood CS4215, Topward 7042
 +^::: |Lightweight  |Would be best low-end scope, except for awkward UI
 +^::: |See also Kenwood, Metrotest
 +^USP |Small, medium speed, easy |Sensitive, printing |
 +^    |{{ :oscilloscope:topward-7042.jpg?direct&100 |}} | {{ :oscilloscope:metrotest-ox8020.jpg?direct&100 |}}|
 +=== For Disposal ===
 +Since they were either faulty or a pain to use, and we had better scopes with these features, in February 2019 we disposed of these scopes: Wavetek 9020, Gould OS300, Tek TDS340, Schlumberger 5602.C, Hameg HM203.
-== High Shelf == +If you want to see their features, look at an earlier revision of this page.
-| ^Tek TDS340 ^Hameg HM203 ^Metrotest OX8020 ^ +
-^Location |High shelf, for occasional use |High shelf, for use during workshops |High shelf, for when Kenwood CS4215 insufficient |  +
-^Domain |Digital, signal integrity |Audio, mechatronics |Audio, mechatronics | +
-^Specification |100MHz, 1V/div, digital |20MHz, 5mV/div, analogue |20MHz, **1mV/div**, hybrid analogue/digital +
-^::: |**Display saved on floppy** | |Dual timebase | +
-^::: | | |Limited DSO features +
-^::: | | |Manual voltage and time cursors | +
-^::: | | |Prints HPGL/HP-PCL to centronics/serial | +
-^Condition |Ch1 broken |Mainly functionalworks nicely |Fully functional | +
-^::: |Ch2 only 1V/div and above |Poor or strange controls |**UI a little odd**; dim lights indicate important settings | +
-^::: |Adequate UI |X-shift knob missing | | +
-^::: |Light | | | +
-^Comments |One of the **higher speed** scopes |OK, unremarkable |**On loan** from Lee Wiltshire +
-^::: |**Only scope with screen capture** | |Similar to Kenwood CS4215, Topward 7042  | +
-^::: |Dispose //after// we get another 100MHz scope with screen capture. | |Would be best low-end scope, except for awkward UI | +
-^USP |Screen capture |Nothing => candidate for disposal |Sensitive, printing |  +
-^    |{{ :oscilloscope:tektronix-tds340.jpg?direct&100 |}} | {{ :oscilloscope:hameg-hm203.jpg?direct&100 |}}| {{ :oscilloscope:metrotest-ox8020.jpg?direct&100 |}}|+
-== For Disposal == +(this will be updated after the move)
-| ^ Wavetek 9020 ^Gould OS300 ^ +
-^Location |Dispose |Dispose, for use  | +
-^Domain |General, audio, mechatronics |General, audio, mechatronics | +
-^Specification |20MHz, 5mV/div, analogue |20MHz, 2mV/div, analogue | +
-^::: |Dual timebase | | +
-^Condition |Some ringing on digital transition |Some ringing on digital transition | +
-^::: |Some channel crosstalk |Some channel crosstalk | +
-^::: |Trigger on -ve slope broken |External trig broken | +
-^::: |Delayed timebase noisy | | +
-^::: |Ch1, Ch2 uncal switch noisy | | +
-^::: |Vert mode controls quirky | | +
-^::: |Poor but could be functional |Usable for simple purposes | +
-^Comments |Adequate low-end scope |Adequate low-end scope | +
-^::: |Repair required |Usable without external trig | +
-^::: | |Lightweight |+
