equipment:floor-standing-pillar-drill [2017/03/14 16:48]
chocojon Added induction notes (14/3/2017)
equipment:floor-standing-pillar-drill [2019/05/04 00:26]
felix.h ↷ Page moved from floor-standing-pillar-drill to equipment:floor-standing-pillar-drill
Line 21: Line 21:
 === Safety === === Safety ===
-Use the following recommended safety equipment for protection while using this machine+  * Be aware of other people around you. Don't bump into them and be respectful of usage space around the equipment.
 +  * Only drill vertically. This is not a mill / CNC machine. Things could go very wrong if the work piece is moved while drilling into it.
 +  * Tie long hair back (prefereably tucking it into clothing). Be aware of beards if appropriate.
 +  * Don't wear loose clothing that might catch on any moving part.
 +Use the following recommended safety equipment for protection while using this machine:
   * Safety goggles for eye protection   * Safety goggles for eye protection
   * Ear defenders for ear protection   * Ear defenders for ear protection
   * Dust masks for prevention of inhalation of particulate matter   * Dust masks for prevention of inhalation of particulate matter
   * Gloves for abrasion resistance (optional)   * Gloves for abrasion resistance (optional)
-Be aware of other people around you. Don't bump into them and be respectful of usage space around the equipment.
-Only drill vertically. This is not a mill / CNC machine. Things could go very wrong if the work piece is moved while drilling into it.
-Tie long hair back (prefereably tucking it into clothing.
-Don't wear loose clothing that might catch on any moving part.
 === Drill bits === === Drill bits ===
Line 42: Line 43:
 === Usage === === Usage ===
   - Move the working platform down from the drill head by loosening the handle attaached to the platform.   - Move the working platform down from the drill head by loosening the handle attaached to the platform.
-  - Insert the relevant drill bit.+  - Insert the relevant drill bit. Ensure the shank of the drill bit goes all the way into the chuck.
   - Tighten chuck with key found on the side of the drill. Tighten well (due to chuck needing to be replaced) so that drill doesn't bite into the material and not drill properly.   - Tighten chuck with key found on the side of the drill. Tighten well (due to chuck needing to be replaced) so that drill doesn't bite into the material and not drill properly.
   - Put chuck key on side of drill into its clip.   - Put chuck key on side of drill into its clip.
   - Raise the working platform to the drill bit and align the hole in the platform with the drill bit. This is so that the surface won't be damaged if you do drill through the work piece.   - Raise the working platform to the drill bit and align the hole in the platform with the drill bit. This is so that the surface won't be damaged if you do drill through the work piece.
-  - Without rotating the platform, move the platform down to allow the work piece to fit into the gap.+  - Without rotating the platform, move the platform down to allow the work piece to fit into the gap. If you need the piece to have clean holes on both sides, use a scrap piece of wood underneath the work piece and allow extra space to fit the scrap piece in as well.
   - Secure the working platform by tightening the handle.   - Secure the working platform by tightening the handle.
   - Make sure that the chuck key is not in the chuck and is in the clip.   - Make sure that the chuck key is not in the chuck and is in the clip.
Line 55: Line 56:
   - Slowly use the three handles on the side to lower the drill into the work piece.   - Slowly use the three handles on the side to lower the drill into the work piece.
   - Carefully use the handles to remove the drill bit from the work piece - do **not** just let go of the handles.   - Carefully use the handles to remove the drill bit from the work piece - do **not** just let go of the handles.
-  - Repeat as often as necessary.+  - Repeat as often as needed.
 === Tidying up === === Tidying up ===
Line 64: Line 65:
   * Put all safety equipment back.   * Put all safety equipment back.
   * Brush the drill and platform to remove excess material. Sweep area around drill press and bin the rubbish.   * Brush the drill and platform to remove excess material. Sweep area around drill press and bin the rubbish.
  • equipment/floor-standing-pillar-drill
