equipment:bandsaw [2020/05/31 22:10]
ryandh
equipment:bandsaw [2020/08/27 17:07]
josephxtian updated location of bandsaw blades
Line 30: Line 30:
 ==== Bandsaw blades ==== ==== Bandsaw blades ====
-  * The spares are located on the shelf below the actual bandsaw. +  * The spares are located on the wall besides the bandsaw.
-  * If a bandsaw blade becomes blunt, replace with a spare from the aforementioned shelf. Do not use the spares if the blade is still sharp - if it's not cutting well, make sure you're not forcing the work piece too hard through the saw. +  * If a bandsaw blade becomes blunt, replace with a spare from the wall. Do not use the spares if the blade is still sharp - if it's not cutting well, make sure you're not forcing the work piece too hard through the saw.
-  * If there are no more spares, comment on the mailing list to get more stock - make a note of whether the metal/plastic blade or wood blade is needed. Alternatively, buy a replacement and request reimbursement through the normal forms. +  * If there are no more spares, comment on the google group to get more stock - make a note of whether the plastic or wood blade is needed. Alternatively, buy a replacement and request reimbursement through the normal forms.
-  * The saw that's suitable for metal or plastic has more teeth per inch (tpi) than the wood one, i.e. finer pitch. Current recommended one is 10 tpi.+  * The saw that's suitable for plastic has more teeth per inch (tpi) than the wood one, i.e. finer pitch. Current recommended one is 10 tpi.
   * The saw that's suitable for wood has less teeth per inch (tpi) than the metal/plastic one, i.e. coarser pitch. Current recommended one is 6 tpi.   * The saw that's suitable for wood has less teeth per inch (tpi) than the metal/plastic one, i.e. coarser pitch. Current recommended one is 6 tpi.
  • equipment/bandsaw
  • Last modified: 11 months ago
  • by josephxtian
