botlab:policies:safe_working [2019/05/23 01:15]
felix.h updates from members meeting
botlab:policies:safe_working [2019/05/30 10:20] (current)
Line 5: Line 5:
 ==== Your Responsibilities ==== ==== Your Responsibilities ====
-You are responsible for your own safety when using the hackspace, and for making sure you do not endanger the safety of those around you. +**You are responsible for your own safety when using the hackspace, and for making sure you do not endanger the safety of those around you. **
 You must: You must:
Line 21: Line 21:
 If you see something that poses an unacceptable level of risk, you must remedy that risk if it is safe to do so and you have appropriate knowledge or experience. You must also report the incident to the Directors or the Google Group and leave a written note on, or in plain view of the hazard to alert other members. If you see something that poses an unacceptable level of risk, you must remedy that risk if it is safe to do so and you have appropriate knowledge or experience. You must also report the incident to the Directors or the Google Group and leave a written note on, or in plain view of the hazard to alert other members.
-If you see someone working in an unsafe way, alert them to the hazard. If someone tells you that you are working unsafely, immediately stop and reassess your working practices.+**If you see someone working in an unsafe way, alert them to the hazard.** If someone tells you that you are working unsafely, immediately stop and reassess your working practices.
 If someone gets injured, narrowly misses getting injured, or a situation is created that could easily lead to injury, you should fill in the incident book (located near the first aid kit in G11) or report the incident directly to the Directors or on the Google Group. If someone gets injured, narrowly misses getting injured, or a situation is created that could easily lead to injury, you should fill in the incident book (located near the first aid kit in G11) or report the incident directly to the Directors or on the Google Group.
  • botlab/policies/safe_working
  • by nick_gover
