botlab:openmeeting_20150325 [2015/03/29 16:05]
dwyatt [Points discussed]
botlab:openmeeting_20150325 [2015/03/29 16:06]
dwyatt
Line 67: Line 67:
     * NM: if the space agreed we should get a smaller cutter and could fund it, he is prepared (within reason) to top up funding to upgrade to A0 size     * NM: if the space agreed we should get a smaller cutter and could fund it, he is prepared (within reason) to top up funding to upgrade to A0 size
     * Discussion on size of laser cutter - having a larger size is beneficial, can we get one with feed-through so we can cut large panels in small sections?     * Discussion on size of laser cutter - having a larger size is beneficial, can we get one with feed-through so we can cut large panels in small sections?
-    * MV: proposed process for large item purchase: (**Action:** will write up and circulate. UPDATE: [[:large_proposal_process draft available]])+    * MV: proposed process for large item purchase: (**Action:** will write up and circulate. UPDATE: [[:large_proposal_process|draft available]])
       * Interested parties put together a proposal       * Interested parties put together a proposal
       * They pitch it to committee       * They pitch it to committee
  • botlab/openmeeting_20150325
