botlab:manual:consumables [2021/07/03 11:22]
mattg
botlab:manual:consumables [2021/07/04 19:42]
mattg
 ====== Consumables ====== ====== Consumables ======
-Consumables are very useful generic things that we aim to keep in stock, for everyone to make reasonable light use of in their projects.+Consumables are useful and generic things that we aim to keep in stock, for everyone to make reasonable light use of in their projects.
-If you are using a large proportion of our stock of any itemthen this is not reasonable light use, and you should buy it yourself rather than deplete the Hackspace supply+Consumables are kept on the consumables boards in the WoodshopMetalshop (TBC), and Electronics Area (TBC). See below for full tables of what should be on each of these boards.
-Consumables are kept on the consumables boards in the WoodshopMetalshop (TBC), and Electronics Area (TBC). There'full table of what should be on these boards further down this page.+If you find a consumable item that is missing or running low, please help out by restocking it. The Treasurer will refund you if you submit the receipt. Make sure you buy the right items from the right supplieror you might not get refund.
-If you find that a consumable item running low or missingplease help out by restocking itThe Treasurer will refund you if you submit the receipt.+If you are using lots of any consumable item in your projectthen this is beyond reasonable light use, and you should buy your own rather than depleting the Hackspace's supply
 +Please don't put anything else on the consumables boards. If you have similar items of your own that you want to donate for others to use, put them in in the "Stuff for Hacking" area.
 +=== Woodshop Consumables: ===
-Woodshop Consumables:
 |**Item**|**Supplier**| **Code ** | |**Item**|**Supplier**| **Code ** |
-| Wood glue 1L| Toolstation | 22271 | +| Wood glue 1L| Toolstation | [[https://www.toolstation.com/p22271|22271]]
-| Sanding roll 10m 60grit  | Toolstation |53602 | +| Sanding roll 10m 60grit  | Toolstation | 53602 |
-| Sanding roll 10m 120grit | Toolstation |76933 | +| Sanding roll 10m 120grit | Toolstation | 76933 |
-| Sanding roll 10m 180grit | Toolstation |35491 | +| Sanding roll 10m 180grit | Toolstation | 35491 |
-| Sanding roll 10m 240grit | Toolstation |33624 | +| Sanding roll 10m 240grit | Toolstation | 33624 |
-| Masking tape 25mm | Toolstation |61281 | +| Masking tape 25mm | Toolstation | 61281 |
-| Impact driver bits PZ2 | Toolstation |11944 |+| Impact driver bit PZ2 x 5 | Toolstation | 11944 |
 | Self-starting wood screws 3.5 x 20 | Toolstation | 80187 | | Self-starting wood screws 3.5 x 20 | Toolstation | 80187 |
 | Self-starting wood screw  4.0 x 40 | Toolstation | 72285 | | Self-starting wood screw  4.0 x 40 | Toolstation | 72285 |
Line 29: Line 32:
 +=== Metalshop Consumables: [Coming Soon] ===
 +|**Item**|**Supplier**| **Code ** |
 +=== Electronics Area Consumables: [Coming Soon] ===
 +|Lead-free solder  | | |
 +|Solder flux paste | | |
 +|Desoldering braid | | |
 +|"Choc Block" Terminal Strip | | |
  • botlab/manual/consumables
  • Last modified: 5 months ago
  • by mattg
